My Carrier furnace is driving me crazy
Hi hifiuser
If you are talking about the drain pan on the evaporator, it can be replaced. If you will give me the model of the evaporator coil I will look up the part number for you. It should be a CK5AXA or BXA coil, I will need all of the number on the evap though. As far as the furnace, I have the exact same one in the upstairs of my house I installed in 1998. The only thing other than the yearly check and monthly filter changes I have ever had to do to this furnace is change out the board, that was due to lightning though. You have a excellent furnace, I think you would be dramatically dissapointed in something else.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
