Old 10-15-2009, 06:43 PM   #1
Default My A/C unit stopped blowing cold air?
Hi, ok I have an ac unit I don't know what it is. Model number H2RA030S06A. When the fan is on it does not heat up, but when I put the AC on the outside unit gets hot the fan isn't running I just hear a buzzing. The freon was changed about 3 months ago and it was cleaned out. Anyone have any idea what it could be? No cold air means miserable family.
srlf is offline   Reply With Quote
Old 10-15-2009, 08:38 PM   #2
An old Tradesmen
H2RA is a York A/C. It is not a heat pump.
Old 10-15-2009, 09:45 PM   #3
So what could the problem be, btw thank you very much I wrote that down.
Old 10-15-2009, 10:39 PM   #4
I had a similar problem and it turned out to be a bad fan motor bearing in the outside condenser. Not sure what the actual repair cost was as I paid a $50 deductable and home owners insurance covered the rest. You might try spinning the fan blade manually using a thin stick between the grates !!!MAKE SURE THE POWER IS OFF FIRST!!!. If it spins freely, this is probably not the problem.
Vizoere is offline   Reply With Quote
Old 10-15-2009, 11:14 PM   #5
thank you I spun it about 10 cycles outside it spins but clicks and dosen't move. I thought it may have just been the motor thank you
Old 10-16-2009, 06:21 AM   #6
An old Tradesmen
Could be a bad fan motor.
Old 10-16-2009, 11:19 PM   #7
How old is it,what type of climate do you live in and did any lawn waste get sucked into the unit. What kind of noise is it making?
Davidj0717 is offline   Reply With Quote
Old 10-17-2009, 08:42 AM   #8
I didn't read anything about whether the compressor is running, so is it?
It could be just a blown fuse or tripped breaker.
sgthvac is offline   Reply With Quote
Old 10-17-2009, 08:45 AM   #9
An old Tradesmen
The outside unit wouldn't get hot when he turns on the A/C, if the compressor wasn't running.
Old 10-17-2009, 08:55 AM   #10
Your right Beenthere, I had a brain fart, just woke, i missed that line pick an excuse .
SRIF- could be bad motor, bad capacitor.
Old 11-14-2009, 07:49 PM   #11
I found out what is was the fan blew..... Jake and I are trying so hard to get this old house fixed up ;...; so many problems so little money lol.... thank you all for your help
Tags
a/c units, cleaned 3 months ago, new freon, not cooling
More On This Topic
In this clip we're going to talk about the proper way to remove and replace an electronic cooling fan. In this step we're going to go over the proper service procedure for removal of the actual cooling fan assembly. And we're going to go over the test... Read More »
Checking your rollerblade bearings for wear is an easy way to keep skates rolling smoothly and safely. Since bearings are cheap and easy to replace, finding wear early can prevent major damage to the skates and injury to you. Follow these steps to check... Read More »
Hi, my name is Mark Delgado with American Auto Service for Expert Village. The one problem that may cause poor AC service is that the condenser may not be properly cooling the high pressure gas and that may not even be an air conditioning system problem... Read More »
Hi, I'm Karen for Expert Village. Okay, we're going to start by preparing our onion. I'm just going to remove the skin, just take off the top of that and take off the little root section. I also have a trash bag set up here that I can just throw my skins... Read More »
My name is Tom Roland and we are at Cottonwood Motor Sports and I am here to tell you about doing service on a Polaris Quad and this is a fairly representative of macho, many of them. Also things that need be looked at are the upper called the tie rod... Read More »
Trane Heat Pump Not Blowing Cold JbIcon HVAC 3 09-01-2009 12:15 PM
Furnace blowing cold air. rileyc HVAC 4 02-19-2009 04:18 PM
HEIL/ICP gas/electric self-contained unit -- blowing cold air, won't shut off AboveTheBULL HVAC 1 02-07-2009 07:48 AM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 11:33 PM
A/C not blowing cold air... rnorred13 HVAC 4 05-18-2008 09:44 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
