My A/C Is Not Blowing Cold Air - HVAC - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 06:30 PM   #1
My A/C is not blowing cold air
The A/C unit is not blowing cold air. The unit outside turns on and is blowing cold air out. Has a new capacitor. What could be the problem? (PS I tried turning on the heat to see if it is working, and it does not turn on at all. Only the a/c turns on) HELP
drosello is offline   Reply With Quote
Old 06-28-2011, 06:49 PM   #2
JJboy's Avatar
Model #?
Heat pump?
Why did you change the capacitor?
Blower is running?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-28-2011, 07:33 PM   #3
Both the outside fan and compressor working or is just the fan?
Old 06-28-2011, 08:30 PM   #4
Originally Posted by JJboy View Post
Model #?
Heat pump?
Blower is running?
Don't know the model number. My husband thought that may have been what went bad. It sounds like the blower is running, I mean it does blow air but it is very warm.
Old 06-28-2011, 08:30 PM   #5
It might be just the fan. There is no cold air. How can I tell?
Old 06-28-2011, 09:15 PM   #6
Check
Check for a refrigerant leak, also a.c. Systems normally have a 15 year life expectance if not maintained properly(changing the filter once a month). If ur an a.c. Guy hook up your r10a gauges
Combustionking is offline   Reply With Quote
Old 06-28-2011, 09:24 PM   #7
Does it sound like the AC always has or does it sound like just a fan running? With no heat coming out the top either the compressor isn't working or there's not enough refrigerant left to transfer the heat. Turn the power off and then check if the compressor wires are in good shape or if one has burnt off.
A/C not blowing cold air... rnorred13 HVAC 9 04-03-2014 04:03 AM
Stops blowing cold air after several hours awathen HVAC 4 06-07-2011 09:31 AM
Outside unit blowing cold air johna_d HVAC 1 04-10-2011 11:38 PM
HEIL/ICP gas/electric self-contained unit -- blowing cold air, won't shut off AboveTheBULL HVAC 3 06-28-2010 07:23 AM
Furnace blowing cold air. rileyc HVAC 4 02-19-2009 03:18 PM
