-   -   My A/C is not blowing cold air (http://www.diychatroom.com/f17/my-c-not-blowing-cold-air-109094/)
drosello 06-28-2011 06:30 PM
The A/C unit is not blowing cold air. The unit outside turns on and is blowing cold air out. Has a new capacitor. What could be the problem? (PS I tried turning on the heat to see if it is working, and it does not turn on at all. Only the a/c turns on) HELP:furious:
JJboy 06-28-2011 06:49 PM
Model #?
Heat pump?
Why did you change the capacitor?
Blower is running?
Marty S. 06-28-2011 07:33 PM
Both the outside fan and compressor working or is just the fan?
drosello 06-28-2011 08:30 PM
Originally Posted by JJboy (Post 676112)
Model #?
Heat pump?
Blower is running?
Don't know the model number. My husband thought that may have been what went bad. It sounds like the blower is running, I mean it does blow air but it is very warm.
It might be just the fan. There is no cold air. How can I tell?
Combustionking 06-28-2011 09:15 PM
Check
Check for a refrigerant leak, also a.c. Systems normally have a 15 year life expectance if not maintained properly(changing the filter once a month). If ur an a.c. Guy hook up your r10a gauges
Marty S. 06-28-2011 09:24 PM
Does it sound like the AC always has or does it sound like just a fan running? With no heat coming out the top either the compressor isn't working or there's not enough refrigerant left to transfer the heat. Turn the power off and then check if the compressor wires are in good shape or if one has burnt off.
