Old 11-11-2012, 09:54 PM   #1
My a/c fan doesn't stop
My a/c fan motor doesn't stop. I have to shut off power completely. Believe that the wires are messed up.
Please advise
Angcab is offline   Reply With Quote
Old 11-11-2012, 10:07 PM   #2
Electrical Contractor
kbsparky's Avatar
Sometimes that is an indication of a blown 24 volt power supply.... either the fuse or transformer ...
Other times it's an indication of leaving the "fan" switched on at the thermostat, or a shorted out control wire ...
-KB
Old 11-11-2012, 10:17 PM   #3
Thanks KB
The "fan" switch is in auto and even shutting off the a/c in the thermostat, the fan still runs.
It was not doing that but I believe that someone messed up the wires as they are all visible.
Is there any way I can verify if the wires are ok? The unit his relatively new, its a replacement unit Goodman, 3 years hold
Old 11-11-2012, 10:45 PM   #4
Disconnect the green wire at the air handler where it comes down from the t'stat. Maybe a bad stat.
bobelectric is offline   Reply With Quote
Old 11-11-2012, 11:03 PM   #5
who says green is connected to G
carmon is offline   Reply With Quote
Old 11-12-2012, 07:21 AM   #6
Take apart one of the little wires out side that comes from inside the house if it don't stop, post back.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is online now   Reply With Quote
Toilet inlet hose/angle stop problem shark974 Plumbing 5 04-21-2011 08:26 AM
How do I adjust hot water limit stop in single handle shower faucet? ThunderCAT Plumbing 2 03-09-2010 03:13 PM
Fire Stop jamiedolan Remodeling 7 03-03-2009 12:39 PM
Hinge Pin Door Stop exterior dws General Discussion 5 02-17-2009 10:58 AM
Hinge door stop fred2007 General Discussion 3 11-11-2007 08:00 PM
