-   -   My a/c fan doesn't stop (http://www.diychatroom.com/f17/my-c-fan-doesnt-stop-163011/)
Angcab 11-11-2012 09:54 PM
My a/c fan motor doesn't stop. I have to shut off power completely. Believe that the wires are messed up.
Please advise
kbsparky 11-11-2012 10:07 PM
Sometimes that is an indication of a blown 24 volt power supply.... either the fuse or transformer ...
Other times it's an indication of leaving the "fan" switched on at the thermostat, or a shorted out control wire ...
Angcab 11-11-2012 10:17 PM
Thanks KB
The "fan" switch is in auto and even shutting off the a/c in the thermostat, the fan still runs.
It was not doing that but I believe that someone messed up the wires as they are all visible.
Is there any way I can verify if the wires are ok? The unit his relatively new, its a replacement unit Goodman, 3 years hold
bobelectric 11-11-2012 10:45 PM
Disconnect the green wire at the air handler where it comes down from the t'stat. Maybe a bad stat.
carmon 11-11-2012 11:03 PM
who says green is connected to G :eek::eek::eek::eek:
COLDIRON 11-12-2012 07:21 AM
Take apart one of the little wires out side that comes from inside the house if it don't stop, post back.
