My Boiler Doesnt Have Any Water In It. - HVAC - DIY Chatroom Home Improvement Forum
Old 09-20-2009, 08:24 AM   #1
Rewards Points: 174
My boiler doesnt have any water in it.
Started the boiler up yesterday to do a test run. After 20 minutes of no heat went down to basement. The area around boiler was much hotter than usual. Turned the system off. I opened up the drain valve and nothing came out. Pressed manual feed but all that did was create an overflow of water from a pressure valve.
What should I do?
Thanks.
Leoskee is offline   Reply With Quote
Old 09-20-2009, 12:25 PM   #2
Rewards Points: 174
Old 09-20-2009, 01:00 PM   #3
Rewards Points: 1,494
Is this forced hot water or steam? For FHW, was the circulator pump(s) running?
Is the pressure valve in a different place from the manual feed?
It is possible for the boiler drain valve to get plugged with sediment, particularly if a small amount of water isn't drained out at the end of each heating season.
Old 09-20-2009, 02:37 PM   #4
I agree with AllanJ, The boiler drain is is probably plugged or defective. The best way to verify water in the boiler is to check the pressure/temp gauge. If it shows pressure at all, the boiler has water in it. If the water ran out of the relief valve the boiler is full. The relief is designed to open at 30psi. As AllanJ suggested, you need to check the pumps and zone valves. Could also have an airlock somewhere.
SKIP4661 is offline   Reply With Quote
Old 09-20-2009, 02:45 PM   #5
Did the boiler ever reach operating Temp ?
Did the pump run at all ?
Was the thermostat on & turned up ?
Has the system/radiators been bled ?
Old 09-20-2009, 06:00 PM   #6
newtech's Avatar
Rewards Points: 164
What should I do?
Thanks.
First ...Your lucky you didn't blow yourself up... Never add cold water to a HOT boiler with no water... Get a pro to check it out...
newtech is offline   Reply With Quote
Old 09-20-2009, 06:29 PM   #7
I agree
I Agree newtech, as a former Boiler Tender in the Navy never introduce cold water in to a hot Boiler.
SULTINI is offline   Reply With Quote
Old 09-20-2009, 08:57 PM   #8
Rewards Points: 174
You guys gave me plenty of of homework to do. I cant answer any questions besides the one about the manual feed and pressure valve. Yes, the pressure valve is directly above the manual feed. I do not have any background knowledge on boilers so this is all new to me. I've been in the house 3 years now and everything has been working well. I did find another valve that I opened up and water came out of it. I then noticed that there is a guage on the side of the boiler and it is completely full of water. I am assuming that the boiler does have water in it. The question now is, why did it heat up the radiators.
Off hand, how long does it take for a boiler to produce enough steam to heat up the radiators direcly above it from a cold start? I waited about 20 minutes. Did I jump the gun?
Old 09-21-2009, 04:39 AM   #9
An old Tradesmen
Rewards Points: 6,890
Depends on how much water the boiler had in it. And the BTU size of the boiler.
To heat 1 pound of water from 50F to 212 F takes 172BTUs per pound of water. It takes another 970 BTUs to turn that pound of water into a pound of steam.
1 gallon of water at 50 F weighs 8.33 pounds. So 1 pound of water, is only about a pint.
Drain your boiler, flush it out. refill to marked fill level.
Steam time could be 25 minutes, or 45 minutes for first time.
Old 09-21-2009, 10:08 AM   #10
Rewards Points: 174
Originally Posted by beenthere View Post
Drain your boiler, flush it out. refill to marked fill level. Steam time could be 25 minutes, or 45 minutes for first time.
How do I do that? Do I just open up the valve and continuously empty out buckets of water or is there another way to do it? Will the boiler fill itselve up on its own or will I have to something else?
Old 09-21-2009, 12:07 PM   #11
An old Tradesmen
Presuming this is a steam boiler.
Hook a garden hose to the boiler drain cock.
Open it, and let it run out. Until its clear.
You may have to run some fresh water into it while draining it.
You should have a manual water feed valve.
Post pics of your boiler and the valves on and near it. Then we can tell better.
Look on your system. To see if it has
Old 09-21-2009, 12:17 PM   #12
Rewards Points: 174
I'll post pics when I get a chance.
My drain valves are near the floor. Is the water under pressure even when it is turned off? I dont see how else I can drain it with a hose.
Old 09-21-2009, 12:22 PM   #13
An old Tradesmen
On a how ater boiler, yes.
On steam, not when the boiler is cold.
Old 09-21-2009, 12:34 PM   #14
The significance of the pressure valve directly above the water feed is that the clog could be just below there there and the boiler really has no water in it while opening the water feed sends water squirting out the pressure valve. This is rare but could have dire consequences if you fire up the boiler empty.
Steam boilers often have a vertical glass tube on the side that shows the water level.
Once every other year should be enough to drain a boiler completely to get sediment out and then refill with brand new water. You will need professional help unless there is a level indicator or other way to verify that you put the proper amount of water back in.
Steam systems with one-pipe radiators admit air via the radiator valves that will facilitate draining the boiler. Other kinds of systems require a valve higher up, perhaps on the boiler itself or on an expansion tank, to be opened to let air in needed to in turn let water out the drain valve down below.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Hot water boiler furnace-insufficient heat Nashman HVAC 2 11-06-2011 06:15 PM
hot water boiler heating raineywillow HVAC 3 12-26-2008 07:51 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
