Old 01-19-2007, 04:34 PM   #1
My blower won't turn off, either
Hi. I have a Goodman GMPN Condensing Gas Furnace. The circulating air blower is on constantly, whether the furnace is heating or not. This is a new occurance. Typically, the blower is only running while the unit is heating. Not constantly, as it is now, thus blowing cold air when the heater turns off. Any suggestions on what might be going on, and what I can do to fix it?
Thanks!
Charmed is offline   Reply With Quote
Old 01-24-2007, 02:03 PM   #2
Thoroughbred Mopar Man
Hi Charmed
First place to look is at the thermostat. Make sure the fan side is in the automatic setting. If this is not the problem you may need a new fan/limit installed to correct the problem.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 01-25-2007, 12:02 PM   #3
Send a message via ICQ to Furnace_dude Send a message via AIM to Furnace_dude
Originally Posted by #CARRIERMAN View Post
Hi Charmed
Good luck
Rusty
The GMPN furnace does not use a rotary fan limit. you may have a bad IFC, wiring or thermostat, but check fan switch first. it may have been bumped
Furnace_dude is offline   Reply With Quote
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
blower runs, with no heat captjack HVAC 6 12-14-2010 03:15 PM
Goodman HVAC gmp100-3 Inside blower problems ray_adrea HVAC 4 06-28-2007 01:31 PM
Induction blower seal ktritz HVAC 4 03-05-2007 09:52 PM
replaced furnace blower now breaker issue Kurr HVAC 5 01-25-2007 10:22 PM
