My Blower Motor Caught Fire - HVAC - DIY Chatroom Home Improvement Forum
Old 07-12-2009, 11:30 AM   #1
My blower motor caught fire
Hi,
recently I was woke up by smell of smoke and found my blower motor to be on fire--luckily, no major damage occurred--
I have pulled the motor and found the ID tag (GE, model # 5KCP39EGT057AS) but have been unable to locate the exact same one online--do I replace it with one with similiar stats? (suggestions?) Do i need to replace the capacitor as well? the one i pulled is 1/3 HP--can i get a 1/2 hp to stregthen the system or bad idea? help appreciated
thanks, jack
JackKarnes is offline   Reply With Quote
Old 07-12-2009, 11:52 AM   #2
No smoke alarm?
First make sure the root cause is the motor.
New motor:
From GE, price probably high.
From HVAC supply house, price medium.
From Grainger, if you can find it, price low.
And I'm thinking the difference in quality is negligible, or that this GE motor could actually be lower in quality than the others.
You could do a public service and raise motor quality by suing!
Or not. . .
Old 07-12-2009, 11:57 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,396
What is the make, model# and serial# of the air handler or furnace? We may be able to find you a generic solution with that info.
Old 07-12-2009, 12:01 PM   #4
do these numbers look right?
Nordyne E2EB-015HB 4 speed, 4 ton 2.9 FLA- 1/3 HP
that help?
thanks for your time
Old 07-12-2009, 12:03 PM   #5
also...
it is in a trailer house (2002 model) so that would explain the low quality thing thanks
i smelled the motor getting hot and about the same time i opened the cover to unit, small flames could be seen--not much smoke
Old 07-12-2009, 12:10 PM   #6
found serial #
serial number to " air handler or furnace" E2E010706844
thx, jack
Old 07-12-2009, 12:35 PM   #7
Hvac Pro
yuri's Avatar
Thats a tough one for me. Trailer furnaces tend to have special high static fans and strange motor mounts on the motors and not generic parts. Perhaps some of the other techs here know more about that unit. You may have to get it from Nordyne.
Old 07-12-2009, 01:17 PM   #8
Failure causes external to the motor:
sustained low voltage
sustained high voltage
impeller drag
Yuri, what is considered "high" static pressure?
In what way are their shock mounts/couplers/isolators strange?
Old 07-12-2009, 02:33 PM   #9
Man, you are so right about high static blower. They gotta blow air thru ducts the size of straws.
Sheesh.
hvaclover is offline   Reply With Quote
Old 07-12-2009, 03:22 PM   #10
Hvac Pro
yuri's Avatar
Yep. And they gas/elec have to be approved for low clearance to combustibles on the sides, DOT approved for transport. Cannot just grab a standard downflow and substitute it.
Old 07-12-2009, 04:38 PM   #11
seems these people are having problems
http://www.google.com/search?hl=en&s...&aq=f&oq=&aqi=
and
Old 07-12-2009, 07:39 PM   #12
HVAC / Plumbing
don't know your location... Look in the phone book for a motor shop.. The local motor shop where I purchase all my motors sells all types of motors. Usually less than OEM
kenmac is offline   Reply With Quote
Old 07-13-2009, 07:48 AM   #13
i dont know about your motor, but a few years ago, my dads blower motor went out on is trailer, i was able to find a replacement at grainger. It was about half the price of oem through the dealer
catmech is offline   Reply With Quote
Old 07-13-2009, 12:14 PM   #14
Another guy on this forum got one for $70 vs. $400.
A lamp in my short wave radio went out; the manuf. wanted $32 for this lamp, but the girl at customer service was naive enough to tell me the spec's on the lamp. It was 32 cents from Hosfelt.com.
Old 07-13-2009, 12:54 PM   #15
slight markup wouldnt you say, truth be known, it was probably made by the same co
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Acceptable Blower Vibration John_NH HVAC 15 11-21-2010 01:49 PM
Furnace will not stay on allenzachary HVAC 32 09-21-2010 09:30 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 05:00 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 09:38 PM
