Is My AC Working? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2013, 07:07 PM   #1
Rewards Points: 326
Is my AC working?
hello All
I have been running my AC unit on and off (off because i turn it off) over past fews days. Today, was a damn hot day.
What i noticed compared to other peoples houses, is that the air that is coming out of my vent is not cold. it just feels like fan blowing air.
The unit pretty much runs 24/7. It doesn't even cycle on and off! And the house doesnt cool.
The model is a Goodman CKL36-1L and its roughly 8 years old.
My house is 2700 sq ft. Should i considering upgrading if i cant fix it. Even if i can fix it, is it the right size?
PTMD
Amitabh is offline   Reply With Quote
Old 06-23-2013, 07:24 PM   #2
Rewards Points: 1,192
Need a tech...
bobelectric is offline   Reply With Quote
Old 06-23-2013, 07:26 PM   #3
Rewards Points: 326
Originally Posted by bobelectric View Post
Need a tech...
sorry, just to clarify, you are asking me to get a tech to come by and take a look at it?
PTMD.
Old 06-23-2013, 07:33 PM   #4
Yes. response to post sounds like low freon.
Old 06-23-2013, 07:33 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
You probably need freon.
sublime2 is offline   Reply With Quote
Old 06-23-2013, 07:34 PM   #6
Rewards Points: 326
can i do freon myself, or should i get a tech?
Old 06-23-2013, 07:45 PM   #7
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Generally speaking, no.
If you need freon you have a leak.
HVAC guy will need to come out to hook up gauges and verify that you need freon before putting it in.
If you DO need freon, be sure to tell the tech you want the bottle weighted before and after the freon is added.
Another option is something called easy seal which will seal small leaks.
That you can do yourself if you choose to.
Old 06-23-2013, 07:54 PM   #8
Rewards Points: 326
That you can download yourself if you choose to.
Thank you
I will most likely get a tech. How much freon does my unit need? So that i know the difference of weight is proper. I am guessing i am asking for the weight before and after so to ensure that the tech put freon in?
Old 06-23-2013, 08:00 PM   #9
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Thank you
Your asking for weight to determine how much he charges. Freon, if it's R-22 runs abt 50to60 dollars a pound.
Keep in mind it could be more or less of an issue of low freon.
But if the units running as normal just not cold air, it's more then likely low freon.
If you look at your air unit in your house and can see a little valve on the outside of it us frozen, has ice on it it's a good indicator of low freon or a dirty A coil.
The Following User Says Thank You to sublime2 For This Useful Post:
MTN REMODEL LLC (06-23-2013)
Old 06-23-2013, 08:12 PM   #10
Get a a/c guy to put gauges on to see pressures. 8 year old unit can be repaired to get you through the season.
Old 06-23-2013, 08:32 PM   #11
An old Tradesmen
Rewards Points: 6,836
If by download, you mean add himself/ not if its an r22 system he can't legally.
Old 06-23-2013, 10:05 PM   #12
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Yea I meant do. Darn auto correct.
Why would it be illegal for the easy seal?
You need EPA cert. To install easy seal?
Old 06-23-2013, 10:58 PM   #13
HVAC Tech/Owner
Rewards Points: 604
1. Even if you put the easy seal in....its still low on R-22 and so far everyone is just guessing thats the problem.
2. I wouldn't put that crap in my worst enemy's system.
Technow is offline   Reply With Quote
Old 06-23-2013, 11:49 PM   #14
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Of course we are guessing.
You are correct that he would still need a charge if the unit is low on freon.
I'm sure he will find out once he calls someone out.
As an HVAC guy this comment dose not at all surprise me.
Old 06-24-2013, 10:58 AM   #15
i don't like any leak stop additive
,either. It might be a leaky schraeder valve or something. Still need freon maybe.
gas dryer not working bcw0801 Appliances 4 05-03-2011 05:11 PM
Water Filled Gas Furance Not working szym0n HVAC 1 02-21-2011 04:46 AM
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 10:05 AM
side by side light swithes not working katkell2645 Electrical 2 10-17-2008 07:22 PM
Two switch in one box: only one working jdtsmith Electrical 12 09-29-2008 01:32 PM
