My AC Sucks, What Should I Do? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 08:00 PM   #1
My AC Sucks, What Should I do?
New to the forum here, looks great! I bought my condo a few years ago and there was a Rheem 9 Classic Heat Pump on the balcony when I moved in. It turns on and off fine, but the pressure of the air coming out seems very low and the air is not very cool. When I got my inspection, the inspector told me the delta temp between air coming out and air coming in was about 10-15 degrees too low when the AC was on. I replaced the filter when I moved in(inside the house) but I'm assuming this thing is OG so the unit itself has gotta be about 22 years old?
I live in SoCal so I don't use the heat much, but this summer has been insanely hot and still is insanely hot. Can't take it anymore, so I'm wondering if these type of units can be fixed with new freon or should I get a whole new unit? I really don't want a whole new unit and probably won't get one so any ideas about what may be wrong with my current one would be greatly appreciated.
wholeinone04 is offline   Reply With Quote
Old 09-12-2012, 09:47 PM   #2
Anything ca be fixed with enough money. I wouldn't stick much in a 22 year old AC that's had a hard life though.
Old 09-12-2012, 09:53 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Have both inside evaporator and outside condenser (heat pump) coils cleaned. While you're on the inside clean the blower motor and wheel and the cage they sit in of all dirt.
Start there.
Thanks.
Doc Holliday is offline   Reply With Quote
Zinsser Cover Stain Sucks Lovegasoline Painting 38 01-20-2017 08:58 PM
Water in our toilet bowl sucks out? Bluwolf Plumbing 6 04-23-2011 09:23 PM
REEB millwork quality sucks tuckerz Building & Construction 0 12-10-2009 10:52 PM
vent sucks cool air instead of blow heat wayneled86 HVAC 3 01-25-2009 10:10 PM
Aluminum Wiring! This sucks. Leenders Electrical 4 05-22-2006 08:44 PM
