Old 08-23-2010, 04:09 PM   #1
Must I replace the coil when I replace the outside condenser unit?
My 16 year old Bryant condenser has burnt and shorted. I am being told that I must replace the coil (a-coil) above the furnace when i replace the condenser. is this true?
plichtenstein is offline   Reply With Quote
Old 08-23-2010, 04:29 PM   #2
I am sure many persons on this site can give you a dozen reasons but the long and short of it is YES you do. Thats 25 years experience talking. I really dont think your old coil will take the new 410A ref anyway.
Kevin
Owener operator
lennoxoemparts
kevins is offline   Reply With Quote
Old 08-23-2010, 05:42 PM   #3
Yes and while your at it replace the heater 2.
COLDIRON is offline   Reply With Quote
Old 08-23-2010, 06:57 PM   #4
Hvac Pro
Old condensor It is an 8 SEER and the new condensor will be 13 SEER or higher and a mis-match with the old coil. Won't work properly.
Old 08-24-2010, 10:35 AM   #5
i have an older condenser (10 SEER) and a newer air handler (13 SEER). everything works perfectly fine, in fact it works better than it ever did before. maybe you are only supposed to mismatch in certain ways.
NitroNate is offline   Reply With Quote
Old 08-24-2010, 03:41 PM   #6
An old Tradesmen
Its less problematic using a 13 SEER coil with a 10 or 8 SEER condenser.
Residential AC Unit - Can a stalled condenser fan cause other problems? bcphoto HVAC 6 04-03-2010 11:09 AM
Evap coil question merlinfolks HVAC 15 07-27-2009 08:20 AM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 01:43 PM
vinyl compressor cover petroman HVAC 4 04-14-2008 04:52 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
