"Must Have" Parts To Save Time. - HVAC - DIY Chatroom Home Improvement Forum
Old 06-12-2011, 01:12 PM   #1
JJboy's Avatar
"Must have" parts to save time.
Since I haven't worked with all brands. I'd like to have "basics" parts like: contactor, capacitor, relay, sequencer etc
Please let me know the parts I most have.
Thanks Y'all
JJ
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-13-2011, 08:57 AM   #2
Rewards Points: 1,532
That's a good one!
bob22 is offline   Reply With Quote
Old 06-13-2011, 05:54 PM   #3
JJboy's Avatar
Any one? yuri, beenthere......
Old 06-13-2011, 07:25 PM   #4
Furnace blower motors- 1/6th to 1/2 HP universal in 208/230 and 120V(one each)
condensor fan motor universal (1/6th-1/3rd HP) one 1075 rpm and one 850 rpm
Capacitors o plenty
TXV's -I carry 4 sizes for R22 and 4 sizes for 410A
Filters- a variety of sizes
a 5-2-1 hard start
PVC and fittings for condensate
thermostats-programable and non for AC and heat pumps
R22 and R410A
Contactors
That will cover most residential problems in the cooling season.
The Following User Says Thank You to Marty S. For This Useful Post:
JJboy (06-13-2011)
Old 06-13-2011, 07:48 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,176
Depends on your local market and what size of units and brands are most common. Marty gave you a good start.
Old 06-13-2011, 09:34 PM   #6
Hvac Pro
yuri's Avatar
You REALLY need one of these tools JJ
http://sensibleproducts.com/ultimatepuller.html
Google it and shop for the best price.
Old 06-13-2011, 10:15 PM   #7
Add a torsion band to the stock. That's not a complete list by any means but I'll use 3-4 of those items every day. Having them on the truck means running an extra 3 calls a day instead of getting parts.
Old 06-13-2011, 10:16 PM   #8
JJboy's Avatar
I have this ultimate puller also I got the inspection camera.
Old 06-13-2011, 10:28 PM   #9
Hvac Pro
yuri's Avatar
A 3/4" step drill bit is very useful. Ram that sucker thru and insert your camera. Google step drill bit.
Old 06-13-2011, 10:31 PM   #10
I'm Your Huckleberry
Rewards Points: 2,270
My two cents: get those caps in 440 volt as you can always go up in voltage but not down.
Example, if you come across a 65/5 440 volt cap that is bad on a job and you have a 65/5 370 volt cap you can not use it.
The other way around and no worries, if it's a 370 that is bad you can permanently stick in a 440.
I only carry 440's.
Doc Holliday is offline   Reply With Quote
Old 06-13-2011, 10:56 PM   #11
JJboy's Avatar
I totally forgot about step drill. Do you know the name of the black cover for the hole?
Old 06-13-2011, 10:57 PM   #12
JJboy's Avatar
I only carry 440's.
Great idea Doc. I just to need find out a good capacitors range.
Old 06-13-2011, 11:12 PM   #13
Keep your terminal box stocked up....double spades, compressor flags, butt splices....also keep a good supply of big blue wire nuts. I replace a lot of those during heating season. Sequencers, contactors, fan relays (the Dico switching relay will work in most applications) and every dual cap combo from 25/5 up to 50/5 should be there, as well as a couple of hard starts. Thermostats, limit switches, fusible links, transformers.......there's no such thing as having too many parts! I also keep a bunch of schraeder valves and caps on hand at all times.
brandonmcginnis is offline   Reply With Quote
Old 06-14-2011, 06:28 AM   #14
Hvac Pro
yuri's Avatar
No. I use silver duct tape.
Old 06-14-2011, 09:19 AM   #15
JJboy's Avatar
Ok, now I just need to find a safe location to drill.
vinyl gutter parts good? darsunt Roofing/Siding 9 06-03-2011 12:20 PM
Parts for Old Barrett Hose Bib smata67 Plumbing 1 05-17-2010 08:12 PM
Cosmetic Replacement of Tub/Shower Parts MrBill_DIY Plumbing 4 06-07-2008 06:53 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
Goodman Air Handler with Missing Parts cougarhsv HVAC 2 01-17-2007 09:14 PM
