Old 11-09-2009, 02:36 PM   #1
Multiposition furnace unused holes
We recently had a new furnace installed and it is a multiposition style. there are some uncovered holes on the side of the furnace that aren't in use. These are pretty good sized holes. One is where the stovepipe would go if it was on that side. Is this normal, or should there be coverings placed over these openings to prevent insects etc from getting in?
MistyLee is offline   Reply With Quote
Old 11-09-2009, 03:03 PM   #2
hvaclover's Avatar
Depends if it's an 80% furnace or a 90%. If it's 90% check your manual as the holes MAY need plugging in that case.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 11-10-2009, 08:03 PM   #3
Thanks, hvaclover for the reply. I think I am going to try and cover them.
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Furnace air filtration advice stephen_smith HVAC 5 01-12-2009 08:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 5 11-07-2008 05:52 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
