Multi Zone Heat Control? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2012, 05:11 PM   #1
Multi zone heat control?
I am a new homeowner and I know nothing about heating control. I have done some searching but cant find any real answers. I have a small home from 1930 but it has 4 zones of heat (20+ year old gas boiler). So I have 4 old school dial thermostats. I also have 1 central AC controller, but I am more concerned with the heat.
My question is, do they make a system where I can have 1 master thermostat that controls the other 3 remotely? And can the remote locations have an override to call or cancel heat if I need it?
The connection in the back of all of them are just 2 wires. I dont know if that matters. I would really appreciate the help! Thanks.
reggie1642 is offline   Reply With Quote
Old 11-05-2012, 06:28 PM   #2
An old Tradesmen
Rewards Points: 6,466
You would need to go to a commercial control system. And it wouldn't be cheap.
Old 11-05-2012, 07:49 PM   #3
Thanks. I had hoped there would be one that operated something like a wireless alarm system. Oh well. Then what is a master/slave system?
Old 11-05-2012, 09:02 PM   #4
An old Tradesmen
Thats when the other zones can only have heating or cooling when the master zone is calling for it. They may or may not reach set temp.
Carrier Zone Control Issues Designer22 HVAC 4 10-31-2012 04:44 PM
Heat pump is not running on Heat mode frank06 HVAC 17 03-13-2012 04:34 AM
1st Floor Heat turned off but pipes for that zone are hot dvsrikanth HVAC 4 10-28-2011 11:50 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Boiler one zone call heat but not fire up Ballastar Plumbing 6 02-13-2010 12:17 AM
