Multi Zone Control Home Heating - ? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-13-2010, 12:41 PM   #1
multi zone control home heating - ?
Saw a system on one of the diy tv shows last night that used balloon pneumatic duct dampers at each register. They were controlled both by in-room wireless send/receive units and a Master Control panel that could assign a room (or group of rooms) to different temperature settings, by day & time.
Inflate/deflate for each pneumatic was done using an in-attic master panel and small air pump. Damper Tubing was run in-duct.
Cost was $5-gk + installation for a 13-zone system.
Anybody ever heard of these? I figure payback would probably be 6-8 years, depending on what part of the country you were in.
SixStrRzr is offline   Reply With Quote
Old 02-13-2010, 12:50 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,826
I saw the same/similar show on This Old House Hour. There are some variables they did not talk about. Whenever you close ducts the pressure increases and you need a ECM variable speed fan motor or bypass dampers to relieve the pressure. If you close too many the A/C can also freezeup etc etc. I have worked in commercial bldgs and pneumatic lines can leak and other problems develop. I am not impressed with that system. The balloons when deflated will still obstruct airflow and less airflow causes A/Cs to freezeup. A proper zoning system uses dampers etc. Doubt if those guys will be in business 5-10 yrs from now and have parts is another concern.
Old 02-13-2010, 12:55 PM   #3
Sounds like an Arzel system.
SKIP4661 is offline   Reply With Quote
Old 02-13-2010, 01:18 PM   #4
Yes, that was the show.
Old 02-13-2010, 01:19 PM   #5
From what I saw on their site,the Arzel uses air-controlled Registers,rather than balloons.
Old 02-13-2010, 03:13 PM   #6
An old Tradesmen
Rewards Points: 6,876
Arzel uses either/both dampers in the duct work, and has registers that have motorized dampers in/on them(for systems with concealed duct work.
Arzel DOES NOT use balloons.
The system you saw on TV uses a bypass when too many zones are closed. Also it opens other zones/dampers if the LAT is too high or low. To protect the system.
Old 02-15-2010, 03:32 PM   #7
Zone Guy
Zoning Systems
SixStrRzr:
There are several zoning systems on the market today. Arzel has built the retrofit market over last 15 years. We feature blade dampers, driven by low-pressure air for longevity and robustness, in all shapes and sizes. Check out our web-site
MAVNAV is offline   Reply With Quote
Old 02-15-2010, 03:58 PM   #8
An old Tradesmen
Your not allowed to post links to your site, since you have a vested interest.
Its considered free advertising.
How ever, you may purchase advertising. Use the contact us at the bottom of the page.
sprinkler zone troubles MrLinux Landscaping & Lawn Care 1 08-14-2009 03:43 PM
HVAC very weak upstairs with zone control installed g8rben HVAC 5 06-14-2009 06:51 PM
New To Hot Water Home Heating System Midicat HVAC 2 10-14-2007 08:12 PM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 08:44 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
