Old 02-28-2010, 04:18 PM   #1
Multi stage heat pump thermostat
Hey, I changed out my thermostat on a multi-stage heat pump and it's working fine in heat and E heat mode, but I have question about the 1st and 2nd stage heat. I have not tried the AC mode, but I believe that is on the reversing value (O) and should be fine. My question is: Is Y1 the 1st stage heating and W2 is the 2nd stage heating then Emergency heat is pulled from the 2nd stage with the compressor locked out?
Below is how I have connected my thermostat, but while connecting it I kept thinking the Emergency was 2nd stage.
Thanks in advance.
Old Thermo: Honeywell CT70(Mercury)
Wiring:
X- Blue
W2 - White
R- Red
G - Green
O - Orange
Y1 - Yellow
New Thermo: Honeywell RTH3100C
C - Blue (Common)
R - Red (Return)
O - Orange (Reverse Valve)
G - Green (Fan)
Y1 - Yellow (1st stage heat?????)
W2 - White (2nd stage heat????)
Emergency - W2 to E connected by Jumper
marriedmanw is offline   Reply With Quote
Old 02-28-2010, 04:41 PM   #2
Houston204's Avatar
Yes, you are correct.
Houston204 is offline   Reply With Quote
Old 02-28-2010, 05:12 PM   #3
Thank you for the quick reply. I was over analyzing the problem and got myself turned around. The previous HO didn't have the E heat jumpered and the old t-stat had built-in jumper on Y1 and W1. Until I started asking on this thread and remembered O is reverse valve, I was thinking cooling mode ran on Y1.
Thanks again.
Rheem Package Heat Pump Newbie03 HVAC 4 02-26-2010 07:32 PM
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 03:21 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 04:23 AM
Heat Pump set back GEAF HVAC 6 01-26-2009 08:49 AM
Easy Heat Pump Question brutis HVAC 6 11-03-2008 11:06 AM
