Mr. Stupid! - HVAC - DIY Chatroom Home Improvement Forum
Old 05-26-2009, 11:07 AM   #1
Mr. John's Avatar
Mr. Stupid!
I accidentally cut the thermostat wiring harness during a attic fan replacement project. I replaced the blown fuse at the control board, repaired the wiring and the system worked. Latter that evening the Thermostat display went dead and now the system is not working although when I trip the switch at the access panel the compressor will cycle on. Please help before my wife kills me! Thanks in advance.
Mr. John is offline   Reply With Quote
Old 05-26-2009, 11:39 AM   #2
An old Tradesmen
Rewards Points: 8,228
Did you recheck your wire repair.
Old 05-26-2009, 11:41 AM   #3
Mr. John's Avatar
Three times and once this morning, it worked fine yesterday evening.
Old 05-26-2009, 11:45 AM   #4
An old Tradesmen
Does teh fuse fit tight.
Does your secondary drain pan have water in it. And a wet switch that may be locking out your system.
Old 05-26-2009, 11:58 AM   #5
Mr. John's Avatar
Yes double checked the fuse this AM. No wet switch and no water in pan. There is no power getting to the thermostat I believe, I'm going to try to jump around the repaired section to test?
Old 05-26-2009, 01:13 PM   #6
If you need advice from other repentant village idiots, you've come to the right place. How's your transformer's input and output power?
dac122 is offline   Reply With Quote
Old 05-26-2009, 01:30 PM   #7
Mr. John's Avatar
"repentant village idiots" Well I ran out to Home Despot and got a new thermostat and guess what? It did'nt fix the problem! Big surprize, so I put it all back together and went up and checked the fuse for the fourth time, pulled it out and had a couple more lying there so I switched it out, put it all back together and the thing now works! Of course it worked last night. Are the ATC fuses just as goofy as the old glass one's? I wonder. Now I'm going to get the fuse and run a few tests with my ball peen hammer!
Stanley Powershot design is kind of stupid....dangerous actually. J187 Tools 27 06-25-2012 10:18 PM
Are people really this stupid?? Scuba_Dave Off Topic 7 05-21-2009 12:07 PM
Think - Am I doing something stupid? Leah Frances Safety 15 01-17-2009 06:40 AM
Embarrassingly stupid question about latex paint joeyboy Painting 7 08-20-2007 09:25 PM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 09:48 PM
