Mr Slim Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 09:50 AM   #1
Mr Slim wiring
I have the MSH24WN model with 22,000 BTU and I can't figure out the wiring.According to the diagram it looks like the outdoor unit is powered directly from the source but also looks like the same source splits off to the indoor unit which has a power cord that looks like it goes with the 220,however the specs state that the indoor unit only needs 115 amp.Are they supposed to be wired to seperate breakers and if so ,is it a 15 amp breaker with that large of a power cord?? Any help would be appreciated, Thanks
Burke is offline   Reply With Quote
Old 03-09-2011, 11:23 AM   #2
Just taking a quick look at the diagram it looks like you can either run you 208 to the outdoor unit, and then feed the indoor the 115v from the outdoor unit.
Or you bring in your 208v to the outdoor and a separate 115v from another source from your breaker panel to the indoor.
Just make sure everything is sized correct and have some sort of disconnect switch at each unit. Good luck.
Hubcap626 is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Mr Slim Ductless wiring? karl3200 HVAC 2 05-30-2006 05:07 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
