Mr. Slim Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 09-24-2013, 08:58 AM   #1
Mr. Slim Wiring
Hello All,
I am sure this is a simple question, but I have read the manual, watched youtube videos and of course looked in the forum, but I am missing something. I am installing a Mitsubishi 28,600 MultiZone cool/heat pump condenser with two mitsubishi 18,000 btu air handlers model MSZFE18NA.
When wiring the electrical I am running a 20 AMP 220 line to the Condenser. Do I also run a separate 220 line to each blower, or run a line from condenser to each blower? It seems people do it both ways? I know you require a control line to each blower but it seems like there are only 3 wire to connect to the blower and I can run 12/3 BNC from condenser to blower.
If anyone knows the best way to do it, please let me know.
Thanks in advance
David51st is offline   Reply With Quote
Old 09-24-2013, 01:14 PM   #2
Rewards Points: 616
from condensing unit to evaporator ..... all the one I have installed are that way....
carmon is offline   Reply With Quote
Old 09-24-2013, 08:40 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Read the manual. The indoor units are powered from the outdoor condenser. Use 14-3 with ground from the outdoor unit connections to the indoor unit connections
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-24-2013, 09:22 PM   #4
Rewards Points: 1,016
The inside air handlers are typically powered from the outdoor unit - the instruction manual should speak to this.
____________
Vince
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 10:43 AM
Old wiring to new wiring Acworld34 Electrical 3 07-11-2011 11:00 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
