Moving Supply And Return Vents - HVAC - DIY Chatroom Home Improvement Forum
Old 09-30-2008, 11:02 PM   #1
N8E
N8
Moving supply and return vents
I own an older (1940's) home that has the supply vents on the interior walls near the ceiling and the return vents on the exterior walls near the floor. I've been thinking of reversing the ducts in the basement so to have it adhere to the current standard of supply on the out walls and return on the interior. Is this worth doing? I was hoping it would improve efficiency and make the rooms feel a bit warmer. Does anyone have experinece witht this? Will it make much of a difference?
N8E is offline   Reply With Quote
Old 09-30-2008, 11:25 PM   #2
1610 CUB's Avatar
Rewards Points: 150
As long as you are moving the air clockwise or anti-clockwise whats the difference? The one way you pull cold air from floor and the windows and replace it with warm, the 'new' way is to push warm air across the windows and temper it on its way back to the furnace. Save your money j
1610 CUB is offline   Reply With Quote
Help with return and supply size XHornet85 HVAC 9 09-17-2008 12:13 AM
Supply and Return Issue billybob45 HVAC 4 07-31-2008 10:44 PM
How many return vents needed? tigerbalm2424 HVAC 9 01-05-2008 11:10 AM
Supply and Return from Laundry Room bjstewa HVAC 7 03-03-2007 12:39 AM
Running Supply to Attic cibula11 HVAC 2 02-06-2007 06:08 PM
