Moving Return And Supply Ducts In A Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 09:55 PM   #1
Moving return and supply ducts in a basement
Hi, I am looking to finish my basement and have a problem with the current location of the HVAC supply and return ducts. They run directly down the center of the basement, perpendicular to the joists. Finishing around the duct work only allows about 6' of clearance. My thought to move the duct work is to 90 the supply and return out of the air handler and run them to an exterior wall. Then i would do another 90 running the return and supply in a sofit along the wall. Then to get them back to the center of the room and back to the duct work going up through the floor, I would like to 90 off the wall and run them in between the celling joists. Is this possible and/or hard to do? What kind of affect will this have on my unit and the air flow.
Thanks for any suggestions/help.
AWeikert is offline   Reply With Quote
Distance between HVAC supply and return vents atlantatd HVAC 4 04-13-2011 09:30 PM
Moving heat from wood stove in basement Mike in MN HVAC 0 11-23-2010 12:04 PM
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 03:39 PM
Moving ductwork to accomodate finished basement Badfish740 HVAC 1 01-13-2010 04:11 PM
Moving supply and return vents N8E HVAC 1 09-30-2008 11:25 PM
