Moving A Refrig - HVAC - DIY Chatroom Home Improvement Forum
Old 07-19-2011, 09:23 PM   #1
Rewards Points: 340
Moving a refrig
Will it harm my freezer lay it down flat to transport?
kt82 is offline   Reply With Quote
Old 07-19-2011, 10:06 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
probably not, but I strongly recommend against it. If you do lay it down make sure that when you get it back upright that you let it sit unplugged for a minimum of 24 hours. I would make every attempt to move it in the upright position.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
kt82 (07-20-2011)
Old 07-19-2011, 10:12 PM   #3
Rewards Points: 6,652
Depends on how old it is. Easier if you have someone with a pick up, just to help move it upright. Otherwise, go by the old rule, and let sit for about a day or so before plugging back in.
The Following User Says Thank You to gregzoll For This Useful Post:
kt82 (07-20-2011)
Old 07-20-2011, 05:21 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 180
you NEVER want to transport a fridge or AC on its side!! The compressor rides on 3 springs inside the hermetic shell. if you move it on its side the horizontal/ lateral force of bumps can over stretch/break the springs and ruin the compressor. they are meant to ride on those springs in a vertical motion.
The Following User Says Thank You to yuri For This Useful Post:
kt82 (07-20-2011)
Old 07-20-2011, 10:45 AM   #5
biggles's Avatar
keep it up right if possible the oil will travel out of the compressor to the orifice and possibly wax up on restart...keep the doors tight with rope wrapped around frezzer and refrig section...if left open the gaskets will expand during tranport....
The Following User Says Thank You to biggles For This Useful Post:
kt82 (07-20-2011)
Old 07-20-2011, 12:07 PM   #6
vln
Underwriter
I transported my fridge on it's side for a 40 minute trip over numerous bumps and potholes and let it sit 2 weeks (I was moving from an apartment so I just let it sit) and it runs just fine. No extra noises, no loss of cooling, etc...
I don't think my fridge had springs though, they looked like flexible rubber pads.
vln is offline   Reply With Quote
The Following User Says Thank You to vln For This Useful Post:
kt82 (07-20-2011)
Old 07-20-2011, 04:57 PM   #7
Rewards Points: 1,216
Listen to yuri and biggles.
# 1 the springs are internal you can't see them if one breaks forget it.
#2 The oil will block up the cap tube forget about it.
#1 and 2 buy a new refrigerator.
COLDIRON is offline   Reply With Quote
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Moving toilet 12 feet, unsure about venting sputnik62 Plumbing 11 05-10-2011 03:32 PM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 07:38 PM
Help moving kitchen sink pflaxman Plumbing 2 09-22-2009 12:19 AM
Kenmore Refrig. Temp. ? kourso Appliances 1 07-09-2007 11:37 AM
