Old 08-24-2010, 02:40 PM   #1
CaptChaos's Avatar
Question
Moving HVAC Vent in Wall
Hi Everyone:
I have a current project that I am working on to install pocket doors in a non-load-bearing wall dividing a master bedroom and office\guest bedroom to create more of a "suite" feel.
The picture below tells the story:
So, I currently have a HVAC (hot air only at this point -- no central air) vent coming up from the floor (this is the second floor). The house was built in 1915 and I don't think that the forced air was there originally.
The vent is connected to rigid flat oval duct, and would prefer not to dig into the floor below to move the vent.
So my question is, can I move the vent over by about 16 inches by running some sort of duct work in floor? Perhaps some flexible duct? Is it possible to connect flexible duct to a flat oval duct? Do they may connectors or flexible flat oval ducts that can be used? Anyone have experience or recommended brands?
Thanks very much for your consideration and time to review my question!
CaptChaos is offline   Reply With Quote
Old 08-24-2010, 03:49 PM   #2
I am not the expert that you are looking for, but I do have 2 questions, which I believe will be relevant to a workable solution. Which way do your floor joists run? Parallel or perpendicular to this wall? If parallel, it seems that you should be able to purchase, or have made by a local heating and cooling contractor, a transition. If perpendicular, I would consider a floor register, or registers, depending on whether you need heat in one room or both.
The Following User Says Thank You to DexterII For This Useful Post:
CaptChaos (08-24-2010)
Old 08-24-2010, 04:58 PM   #3
CaptChaos's Avatar
Hi Dexter:
Thanks for the response. Floor joists run parallel to the wall, so I think I should be able to move it over in the cavity created by the joists. I have pulled up the floorboards and verified it. I still need to lay a new floor, so putting it in the wall is preferable to save me work down the line, but not the only option. A floor register can work if it is the better solution.
Cap'n
Old 08-24-2010, 07:56 PM   #4
CaptChaos's Avatar
Here's a photo to help visualize the situation further.
Tags
duct, hvac, round oval, vent
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 06:48 AM
question about a direct vent gas wall furnace utilitylocator HVAC 1 03-16-2010 09:52 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-06-2005 12:03 AM
