Moving HVAC System - Can I Go Without Gas For A Few Days? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-29-2011, 09:25 PM   #1
Rewards Points: 304
moving HVAC system - can I go without gas for a few days?
Hey all,
I'm having my HVAC and HWH moved in prep for a basement finishing. Both are gas.
The HVAC guy can't complete his work without the gas line run - but the plumber will do that. The plumber can't complete his work until the exhaust line is run from the HVAC as the HWH will tap into it.
So I don't know in what order I can make this happen.
I was thinking maybe the HVAC guy doesn't need the gas. It's warm enough now where I don't need heat. So he could just do all his work and run the exhaust. Then the plumber could do his thing but also hook up the HVAC to the gas, even though that might not normally be his job?
My fear is that if the HVAC guys leaves (or "is done") before he knows the furnace and gas to HVAC is working...I mean, maybe he'd want to test the exhaust for leaks, etc. - but wouldn't be able to do that without a working system.
Thoughts?
denemante is offline   Reply With Quote
Old 03-29-2011, 10:55 PM   #2
Talk to your plumber and hvac tech, as they are the ones doing the work and know the full scope of what needs to be done. We could ask you a hundred questions and still not get the full picture as accurately as the pro who actually gets to see it first hand.
hvac benny is offline   Reply With Quote
Old 03-30-2011, 04:55 AM   #3
An old Tradesmen
Rewards Points: 7,298
Yep, they should be able to coordinate themselves to be there the same day/days.
UV Light for HVAC System handy man88 HVAC 12 11-08-2015 08:36 PM
what is a 2 stage HVAC system? viper HVAC 4 09-30-2010 01:42 PM
HVAC system heat won't run with standby generator running... PTighe Electrical 70 09-14-2009 05:35 PM
Need Help picking new HVAC Split System biggerdaddynj HVAC 21 05-29-2009 07:41 AM
What's prevents a good HVAC system install? Yoyizit HVAC 9 04-29-2009 05:03 PM
