Old 01-08-2009, 07:46 PM   #1
Moving a heat pump
I have a Comfort Maker Softsound 1200+ heat pump and it is about 10 ft from the furnace. I am putting an addition onto my house and need to move the unit another 18ft. Is that ok or is that two far away for the copper line. All together it will be approx 30ft. Any help is appreciated.
jmeitz is offline   Reply With Quote
Old 01-08-2009, 09:31 PM   #2
hvaclover's Avatar
Moving a heat pump
I would say probably but I'll defer to the HP guys here
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 01-08-2009, 10:04 PM   #3
JohnH1's Avatar
Moving a heat pump
No problem that sounds well within the limatations. Assuming this is a normal basement to yard setup and not having a larg lift for example ground to a 3rd floor airhandler or something.
JohnH1 is offline   Reply With Quote
Old 01-08-2009, 10:31 PM   #4
JohnH1's Avatar
Moving a heat pump
I can not reply to a PM untill after 20 posts I guess.
So
I am in the Chicago area with 26 years exp. I don't do a lot of heat pumps but enough to know the basics. I run a dual fuel in my own home.
Old 01-08-2009, 10:41 PM   #5
hvaclover's Avatar
Moving a heat pump
Welcome friend.
Old 01-08-2009, 10:45 PM   #6
Home Air Direct's Avatar
Moving a heat pump
No problem with the extension. 50 ft is not uncommon. Your installer will of course have to add additional refrigerant charge to cover the added length in order to attain correct pressures.
btw...Dual Fuels are a great idea
Good Luck
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 01-08-2009, 11:31 PM   #7
Moving a heat pump
Depending on the actual size of the unit and air handler, the manufacture may recommend to increase the size of the lineset from the air handler and heat pump.
On my system, the break point was 25' from the air-handler.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-09-2009, 05:36 AM   #8
An old Tradesmen
Moving a heat pump
No problem with going from a 18 to 30' line set.
With possible exception that it may need a larger vapor line.
Also. Have the contractor run a new line, instead of just extending the current one.
This eliminates a possible joint leak in a crawlspace, or hard to get to area, later down the road.
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
