Moving Condenser Electrical Disconnect, Required? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-27-2009, 09:05 PM   #1
Rewards Points: 29
Moving condenser electrical disconnect, required?
I'm getting bids on replacing my heat pump, one company said the disconnect must be moved since it doesn't meet the current regs. (which I gather are the same for an electrical panel, 36" depth, 30" wide).
The house was built in '95. They used aluminum wire, 6/2 with ground, and if I have to move it, I'll do it myself and switch to copper. I was curious though if it really has to be moved just because of the condenser replacement?
Dave Carney is offline   Reply With Quote
Old 07-27-2009, 09:22 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 150
I would talk to your local electrical inspector. Aluminum wire is HORRIBLE and I would get rid of it. The new heat pump probably uses less juice so you may be able to use a smaller wire. Depends on the ampacity rating of it and your local code. A simple pull plug disconnect is usually all that is required. You may have to downsize your breaker at the panel if the new unit uses less amps.
The heat pump needs proper drainage and should not be sitting directly on the ground. On our Pro site we have pics of a badly damaged unit that did not drain properly and damaged the coil from repeated freeze/thaw action.
http://www.hvacsite.com/f7/condenser...going-bad-101/
Old 07-27-2009, 09:24 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
Dave,
Derby ks here in hays ks that disconnsect is fine. #6 shoukd be fine but I would up grade it to copper.
Code requires a disconnect within 25 ft of appliance and within sight.
This is not considered a load center and does not have min distance requirements for access like a load center does.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 07-27-2009, 09:29 PM   #4
Rewards Points: 560
Here most are wired #10 copper unless it is a 4 or larger ton unit.
Heck, do you even have an inspection office in derby?
Old 07-27-2009, 09:35 PM   #5
Rewards Points: 29
Thanks for the replies. The new heat pump requires the same min amp circuit of 27.x amps. Currently protected by 30 amp breaker, which I'll keep. I hate wasting money but I think in this case I'll go ahead and do it. I'll use #8 copper even though #10 would actually be legit.
I'll just run the wire, mount a new box now, and then do the disconnect/connect in the panel the day before the install. Actually..no...they'll need the power to pump the r22 into the current condenser...so, i'll make the final connection after that.
Old 07-27-2009, 09:37 PM   #6
Rewards Points: 29
We're actually outside the city limit....so all we get is county inspection but I would be surprised if there was any inspection at all after this is all done.
Old 07-27-2009, 09:43 PM   #7
Rewards Points: 560
Worked in Ellis, Rush, Barton, Rice and Pawnee counties and yet have had a county inspection.
Most smaller cities require a license, no permits and no inspection.
Bigger cities like Great bend, Larnard, Hays and Victoria require inspections
Make sure your installer has taken the state test. There are alot of guys in our state that are not state tested simply because the smaller towns don't require it. I'm licensed as an eletrician in a couple of towns and have not taken the electrical exam. I have taken the exam for plumber, gas fitter and mechanical as a master.
Good luck
Old 07-27-2009, 10:34 PM   #8
as seen on tv
Rewards Points: 150
Inspectors in are area like to see disconnect 3' min and uf cable, conduit, or liquidtite. Aluminum is not used anymore.
qbert is offline   Reply With Quote
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Moving a Fridge, is a dedicated circuit required...or not? Snowy334 Electrical 7 07-03-2009 12:36 PM
Moving oven and cooktop to island; need electrical advice worldtravelerall7 Electrical 3 06-17-2007 03:32 PM
moving an electrical outlet bobo Electrical 4 05-21-2005 12:15 PM
