Moving Cold Air Return In Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 09-28-2011, 10:47 AM   #1
Rewards Points: 12
Question
Moving cold air return in basement
Hi Everyone,
I'm currently in the process of finishing our basement. Previously the builder had placed the cold air return in between the joists with the vent located in the ceiling of the basement center. As part of the basement reno, I'm dividing the basement into 2 rooms, so I need to move the cold air return so:
  • Each room has it's own return
  • Returns are located closer to the floor
I'm planning to extend from the existing return duct location and have it run to a stud cavity (sealed by drywall) in each room. To accomplish this, I plan on using rectangular ducts to extend over to the walls where the vents will be (about 5 ft). The rectangular duct will run perpendicular to the joists and will overlap where the original return was located in the joist cavity.
My questions are:
  1. Is there a preferred method to transitioning from the joist cavity to a rectangular duct? How should this joint be sealed?
  2. When running the duct to the stud cavity, I'm removing the top plate of the wall to insert the duct. How does this end get sealed?
Thanks in advance...
djinlondon is offline   Reply With Quote
Old 09-28-2011, 11:15 AM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,882
Just take out that vent and extend it. If you have to drop below the joists to get it there, you may have to, otherwise, if both rooms are next to each other, place the vent in that wall, but do not use the same stud space for both rooms. Since the cold air return looks like it expands across two joist spaces, that will work for what you need.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Tags
cold air return , duct design
Cold Air Return issue ra1185DIY HVAC 1 12-05-2010 04:21 PM
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 03:39 PM
Weak Cold Air Return sbhcom HVAC 1 12-11-2009 02:14 PM
Basement return air ducting - flex or metal? BasementVirgin HVAC 5 10-29-2009 01:01 PM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 01:43 AM
