Moving Cold Air Return - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2011, 07:57 PM   #1
Moving cold air return
We want to remove a wall in between our family room and living room to make one large room. There is a cold air return in the wall in between these two rooms. The plan is remove the wall and have the cold air return in the floor. Would this cause a problem of any kind with the A/C? Im hoping that when the wall is removed that the metal can just be trimmed off and the vent stay in the current location but be in the floor.
jat123 is offline   Reply With Quote
Old 10-05-2011, 08:06 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
No problems at all as long as the system receives the same amount of return air. Why not on the ceiling?
Doc Holliday is offline   Reply With Quote
Old 10-05-2011, 08:13 PM   #3
The furnace unit is in basement right below this cold air return. I don't want to run this air into the attic. Actually what I will be doing is taking down the wall and cutting away the metal of the return and then making the return in the floor. Was hoping that it wouldn't change anything since the return will be approx 6' lower than it is now.
Thanks for your help.
Old 10-05-2011, 10:21 PM   #4
REP
As long as you maintain the size or make it a little bigger even,you will be fine if you were fine with the wall return to start with.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
jat123 (10-06-2011)
Adding on to cold air return agicr HVAC 13 03-27-2011 01:33 PM
is my cold air return opening too small??? cbendock HVAC 2 02-27-2011 03:37 PM
tapping into cold air return Mr Chips HVAC 4 02-24-2011 07:24 AM
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 02:39 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 01:44 PM
