Moving AC Refrigerant Line - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2011, 04:23 PM   #1
EIT/DIY'er
Moving AC refrigerant line
How difficult a task is this, and what is involved?
My refrigerant line runs exactly below where my new toilet will be. The line is only a few inches from where it penetrates a joist, so I cannot bend it out of the way. Additionally,I don't have many options for moving the new toilet, so I'm stuck with moving the line.
Lattimer is offline   Reply With Quote
Old 12-01-2011, 04:33 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,842
not a DIY task. need a tech to remove the freon, cut the line, weld a new piece in to extend it, leak check it, pull a vacuum and recharge the unit. approx 4 hrs work @ $75-100/hr plus some materials and use of company equipment etc etc = $500 and up.
Old 12-01-2011, 04:36 PM   #3
EIT/DIY'er
Bummer. Thanks for the info. I found some additional info online that backed that up.
Any HVAC guys in WNY willing to work for a few beers?
Old 12-01-2011, 04:41 PM   #4
biggles's Avatar
picture would help if you can....to open up a system freon work,and all the rest is a waste of money.if the insulated suction and raw copper line go thru a wood joist cut a hole-slot adjacent jig saw ,recip saw... to the piping and slide it over till it clears the toilet drop.....
Cold Refrigerant Line...Warm Supply camryman95 HVAC 7 06-30-2011 05:29 PM
Gas line for pool heater BillyDIY Plumbing 3 06-10-2011 02:29 PM
Insulating refrigerant gas line all the way to the compressor fritzycat1 HVAC 3 09-11-2009 05:09 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
