Moved Thermostat - Now No Heat. - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2009, 11:22 PM   #1
Moved thermostat - Now no heat.
I have relocated a thermostat that controls a ComfortMaker Model C9MPV075F12C1. The furnace functioned properly prior to the move. I was very careful in reconnecting the wires the same way they were disconnected. When the thermostat calls for heat, it clicks on, but nothing happens now at the furnace. No exhaust fan, no flame. The board fuse has not blown and I have tried a power off cycle to no avail. The LED diagnostic light is blinking "heartbeat" indicating no problems. Any suggestions?
Bernan is offline   Reply With Quote
Old 11-14-2009, 11:49 PM   #2
Houston204's Avatar
Rewards Points: 556
Probably a broken wire behind your stat.
http://icpindexing.mqgroup.com/docum...4004202402.pdf
Houston204 is offline   Reply With Quote
Old 11-15-2009, 01:16 PM   #3
Talking
Problem corrected
On Houston204's advice, I rechecked all of the connections and wires for the umpteenth time, it came down to not enough insulation stripped from one wire. Thank you for giving me someplace to start!
I have heat again!!!
Tags
comfortmaker , furnace repair diy , no heat
changed thermostat on York Affinity, now no heat? sotwell HVAC 1 03-01-2009 06:34 PM
Moved thermostat, now no heat GeauxCajuns82 HVAC 4 02-03-2009 08:36 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
