Moved Thermostat, Now No Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2009, 09:22 AM   #1
Rewards Points: 45
Moved thermostat, now no heat
I moved my air return duct from the lower wall to the ceiling and I'm converting the space behind the wall to a hall closet and so I moved my digital thermostat to the opposite wall. I have a 4 wire system and when I removed the wires I forgot to write down where they went. There is blue, red, yellow, and white wires. The blue still had the "to fan" tag on it so I installed that one correctly. The other labels have a Rh, Y, and W so I assumed that stood for Red, White, and Yellow and I connected them accordingly. But when I turned everything back on and set the thermostat to "heat" the fan blows but the air is not hot. So I obviously mixed up on of the red, white, and yellow wires. Is there a standard for which wires go where? If I look in the attic on the unit itself will the terminals be labeled?
Matt
Lafayette, LA
GeauxCajuns82 is offline   Reply With Quote
Old 01-13-2009, 12:50 PM   #2
Trace the wires back to the furnace board and re hook up to stat the same way they are on furnace board.
hvaclover is offline   Reply With Quote
Old 02-03-2009, 05:50 PM   #3
Perrault
How wires should be wired for older conventional thermostat migration
Wire Color | Thermostat terminal
White -> White
Blue -> Yellow
Green -> Green
Red -> Rh
-Perrault Jean-Paul
pj22 is offline   Reply With Quote
Old 02-03-2009, 06:18 PM   #4
What if I have yellow black green and red?
Old 02-03-2009, 07:36 PM   #5
biggles's Avatar
(stat...color wire coming into stat) Rh is RED.......G is blue.......Y is yellow....W is white
programmable thermostat + heat pump Potomac101 HVAC 10 12-03-2008 10:02 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
Heat kicks on without thermostat bgd73 HVAC 1 05-23-2008 08:17 PM
