Move Furnace To Outside Shed - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 09:49 AM   #1
Move Furnace to Outside Shed
To bring more space inside my house and run heat to more places, what is the code around building a shed on the side of the house and housing the furnace in it. The shed would be built on the side of the house and would run up to the attic where I can feed the heating down. The shed would be located next to the chimney so I can vent it right into the chimney like it is currently doing.
Its a oil furnace.
fixnlife is offline   Reply With Quote
Old 01-24-2011, 10:31 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,394
Ayuh,... If this thing is an extension of the house, it ain't really a shed...
I'm sure you'll need to review your Local building codes to see if it can be done...
Another issue will be, if this is an Unconditioned space, the Heat Loss will be so High, the rest of the house will be Cold...
In other words, the hot air will be cold, before it gets where ya need it...
Bondo is online now   Reply With Quote
Old 01-24-2011, 11:07 AM   #3
Rewards Points: 1,514
I have seen furnaces installed outside a building, sometimes under a gazebo type roof.
Both the feed and the return lines (for both forced hot air or forced hot water) need to be insulated to minimize heat loss on the way to the building.
Old 01-24-2011, 11:36 AM   #4
The space will be enclosed, insulated and sheetrocked on the inside. The space would be uninhabitable because it is just designed to house the furnace.
What is the topic that I would look this up under for the local code?
Old 01-24-2011, 12:31 PM   #5
call your local city hall or building department.
If you live in a residential sub-division neighborhood I can pretty much hear them say no.
If you are in a climate where winters are even mild you will regret using ceiling registers. The warm air will usually float around waist level. You always feel cold from the waist down.
hvaclover is offline   Reply With Quote
Tags
code , furnace , move
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Furnace front clearance owner95112 HVAC 19 12-19-2010 12:22 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 08:47 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
