Move Furnace To Attic - HVAC - DIY Chatroom Home Improvement Forum
Old 11-29-2011, 04:18 PM   #1
Move Furnace to Attic
My home is in Los Angeles, CA. I was looking into putting in new ductwork and moving furnace into attic to increase airflow throughout house. The tech I had out went in attic and noticed that I have "prefabricated" support beams for the roof (series of triangles as supports). He stated that since these supports are prefabricated they are only meant to carry the weight of the roof and that we could not relocate the furnace to roof (issue with city code?). Is this correct?
STarrab is offline   Reply With Quote
Old 11-29-2011, 04:47 PM   #2
I thought you said you were moving the furnace to the attic not the roof?
Old 11-29-2011, 04:57 PM   #3
Call the city building and permit department and ask. I see furnaces in truss framed attics all the time here but this isn't LA
Old 11-29-2011, 06:57 PM   #4
Most furnaces weigh about 100 lbs, evap coil another 25 or 30 lbs max and the duct work if its duct board (i am assuming that since its going in an attic you will be using insulated duct?) doesn't weigh much at all.I don't see that weight being a problem considering how far the weight will be spread out.
harleyrider is offline   Reply With Quote
Tags
airflow , attic , furnace , relocate
moving attic furnace cwbymarc HVAC 4 04-18-2011 05:06 PM
Attic furnace and insulation smh73 HVAC 6 08-07-2010 06:18 AM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
