Move Flue Pipe - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2010, 12:42 PM   #1
Move flue pipe
i need to get my gas furnace flew pipe out of the middle of my dining room. Can i elbow it over in the basement, come up against the wall upstairs, then elbow back over to the original place it was in the attic, then out through the roof?
brdshw45 is offline   Reply With Quote
Old 01-25-2010, 01:02 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,158
NOT a good idea. Furnace venting is supposed to run straight and horizontal with a 1 inch per 10 feet slope upwards and a MINIMUM of elbows. You can get pressure switch tripping problems or fumes spilling out the front of the furnace if it is not done right.
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 02:53 PM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 04:51 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
