Old 10-01-2012, 07:07 PM   #1
Mouse odor in furnace?
One of my vents smells like a dead mouse but my wife says mouse urine. Hard to get to 8' run, lots of other lines under it. Nothing found in furnace. What to do?
Kit Hoover is offline   Reply With Quote
Old 10-01-2012, 08:12 PM   #2
check all vent lines best you can ,remove supply air vent get a dollar store mirror that will fit into duct and use this method to check these pipes you may need a flashlight to , yull need to gain acess to main trunk line and look see , some rentall places have cameras to fish into lines ,if trunk not accessable check inside main duct (plenum) comming off furnace and in between heat exchanger , shud you not find anything in ducts id start there, if only in the one line might be eaiser find
hvac dude is offline   Reply With Quote
Old 10-01-2012, 08:30 PM   #3
how
A forced air heating system is a natural dehydrator. Unless you have a source of water into a duct, a dead mouse will be be bone dry and pretty scentless in a week. (A rat in twice that length of time). Mouse pee is only likely as a smell if there is continuous mouse travel in that duct. (Mice just dribble as they run)
A UV light shows up mouse urine and thats what pestcontrol folks use to find out where mice are traveling.
how is offline   Reply With Quote
Old 10-01-2012, 08:48 PM   #4
creeper's Avatar
I hate when that happens !!
Trust me you will know the difference. Mouse pee is gross. Dead mouse is overwhelming gross and it will fill the whole house, but the good news is that your house will only be overwhelmingly and intensely disgusting for a few weeks
creeper is offline   Reply With Quote
Old 10-02-2012, 02:33 AM   #5
Still Learning
I was at us air last week and I saw this deodorizer cream you pit in your ducts. It smelled bomb like clean laundry. Check it out
thehvacguy is offline   Reply With Quote
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
