Mouse Chewed Through AC Fan Wire - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-02-2010, 02:37 PM   #16
An old Tradesmen
Rewards Points: 7,332
Originally Posted by liquidvw View Post
And how has the western union spliced changed?
Thats the problem. it hasn't. And it wasn't a good splice to begin with.
It has its place. Just not in 99% of the splices made.
Old 06-02-2010, 04:49 PM   #17
Post a diagram of a splice you recommend.
Old 06-02-2010, 05:22 PM   #18
An old Tradesmen
Standard pig tail is all that is needed. Stranded wires shouldn't be wired nutted together, unless its a locking wire nut, or a crimping wire nut.
However, few use more then a standard wire nut.
Figure 12 in that PDF.
Old 06-02-2010, 05:41 PM   #19
Besides the mechanical strength angle, I think the appropriate splice method vs. wire type vs. wire size very much depends on the current that the splice is asked to carry.
This kind of info is probably scattered all over the Web.
Old 06-02-2010, 08:45 PM   #20
An old Tradesmen
Since we're talking about a fan motor. The load on this splice isn't much.
Old 06-02-2010, 10:09 PM   #21
MXer
3 legged dog's Avatar
From what I have seen, any time tape is used on a splice that is exposed to the elements the tape only seals moisture in. Then the splice rots away.
3 legged dog is offline   Reply With Quote
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
wire running question ponch37300 Electrical 4 04-21-2009 03:58 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
