Mouse Chewed Through AC Fan Wire - HVAC - DIY Chatroom Home Improvement Forum
Old 05-17-2010, 09:15 AM   #1
Do work
Rewards Points: 81
mouse chewed through AC fan wire
I was cleaning my exterior AC unit this weekend and noticed that a mouse chewed the purple wire that goes to the fan in the AC unit. I figured I could just cut the wire two and splice it back together with a wire nut. That doesn't seem to be the case as the wire is only 18 gauge stranded but the insulation is really thick so I can't put a nut on there. My other issue is that the splice won't be in a box.
Any ideas on the best way to fix this? A new fan is over $200 so I'd rather not go that route.
Thanks.
liquidvw is offline   Reply With Quote
Old 05-17-2010, 11:30 AM   #2
Rewards Points: 29
Similar thing happened to my brother, his dog chewed through the wires....we fixed it with those crimp on wire connectors that have gel sealant built into the connector. Makes a nice, permanent, water proof repair. You can get them at your local big box home improvement store.
Dave Carney is offline   Reply With Quote
Old 05-17-2010, 12:42 PM   #3
Or solder, with heat shrink tubing.
Old 05-17-2010, 02:12 PM   #4
ews
Portlander
ews's Avatar
Time to set down some mice traps. Make sure ya' put some cheddar cheese in the middle.
ews is offline   Reply With Quote
Old 05-17-2010, 02:17 PM   #5
I use peanut butter and I set the trap with a hair trigger.
One trap on a shelf over my workbench disappeared.
A week later I'm on a job and when I open my toolbag, here is the trap with a dead, stiff mouse in it.
Old 05-17-2010, 02:47 PM   #6
I have found that people who use poison instead of traps have this problem. For some reason they think they will get water by chewing the wires.
Sparky8370 is offline   Reply With Quote
Old 05-17-2010, 03:06 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
Get a BIG ole cat. Will eat the rodents and scares away the wire chewin dogs. Or call "Billy the Exterminator", was watchin his shows on A@E, nothin he won't go after! Trapped a Bobcat, BIG teeth on that cat.
Old 05-17-2010, 03:36 PM   #8
Do work
Rewards Points: 81
O but I got the mouse. I closed up the AC unit and went back in later that day. Sure enough the mouse was sitting there. I had an empty garbage can near by so I flipped him in there. My mouse problem is fixed... At least until the next one moves in.
Old 05-17-2010, 04:42 PM   #9
the Musigician
DangerMouse's Avatar
I set traps in my workshop outside and they'd disappear occasionally too.... I took to adding a chain to them and screwed the chain to the walls....
Worked fine until MouseZilla moved in and broke the trap and chain right off the wall! I STILL can't find the trap/chain/mousezilla..... (chipmunk? raccoon? LOL)
DM
Old 06-02-2010, 11:21 AM   #10
Do work
Rewards Points: 81
I followed these instructions to make a western union splice. I then wrapped the splice with exterior rated electrical tape. Then wrapped that with some good electrical tape.
Old 06-02-2010, 11:46 AM   #11
Rewards Points: 338
seconded. solder paste and a butane torch with some heat shrink tubing will make quick work of it.
NitroNate is offline   Reply With Quote
Old 06-02-2010, 11:51 AM   #12
An old Tradesmen
Rewards Points: 6,916
Wrong type of splice.
Can become a loose splice from expansion and contraction in just a few years. And burn up your motor.
Old 06-02-2010, 12:58 PM   #13
Do work
Rewards Points: 81
I did the WU splice and followed it up with solder. Hopefully that will stay together.
Old 06-02-2010, 01:24 PM   #14
Anything written in 1926 can't be wrong
Old 06-02-2010, 01:39 PM   #15
Do work
Rewards Points: 81
And how has the western union spliced changed?
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
wire running question ponch37300 Electrical 4 04-21-2009 03:58 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
