-   -   mouse chewed through AC fan wire (http://www.diychatroom.com/f17/mouse-chewed-through-ac-fan-wire-71384/)
liquidvw 05-17-2010 10:15 AM
I was cleaning my exterior AC unit this weekend and noticed that a mouse chewed the purple wire that goes to the fan in the AC unit. I figured I could just cut the wire two and splice it back together with a wire nut. That doesn't seem to be the case as the wire is only 18 gauge stranded but the insulation is really thick so I can't put a nut on there. My other issue is that the splice won't be in a box.
Any ideas on the best way to fix this? A new fan is over $200 so I'd rather not go that route.
Thanks.
Dave Carney 05-17-2010 12:30 PM
Similar thing happened to my brother, his dog chewed through the wires....we fixed it with those crimp on wire connectors that have gel sealant built into the connector. Makes a nice, permanent, water proof repair. You can get them at your local big box home improvement store.
Yoyizit 05-17-2010 01:42 PM
Or solder, with heat shrink tubing.
ews 05-17-2010 03:12 PM
Time to set down some mice traps. Make sure ya' put some cheddar cheese in the middle.:wink:
Yoyizit 05-17-2010 03:17 PM
I use peanut butter and I set the trap with a hair trigger.
One trap on a shelf over my workbench disappeared.
A week later I'm on a job and when I open my toolbag, here is the trap with a dead, stiff mouse in it.
Sparky8370 05-17-2010 03:47 PM
I have found that people who use poison instead of traps have this problem. For some reason they think they will get water by chewing the wires.
yuri 05-17-2010 04:06 PM
Get a BIG ole cat. Will eat the rodents and scares away the wire chewin dogs.:thumbsup: Or call "Billy the Exterminator", was watchin his shows on A@E, nothin he won't go after! :no: Trapped a Bobcat, BIG teeth on that cat.
liquidvw 05-17-2010 04:36 PM
O but I got the mouse. I closed up the AC unit and went back in later that day. Sure enough the mouse was sitting there. I had an empty garbage can near by so I flipped him in there. My mouse problem is fixed... At least until the next one moves in.
DangerMouse 05-17-2010 05:42 PM
I set traps in my workshop outside and they'd disappear occasionally too.... I took to adding a chain to them and screwed the chain to the walls....
Worked fine until MouseZilla moved in and broke the trap and chain right off the wall! I STILL can't find the trap/chain/mousezilla..... (chipmunk? raccoon? LOL)
DM
liquidvw 06-02-2010 12:21 PM
I followed these instructions to make a western union splice. I then wrapped the splice with exterior rated electrical tape. Then wrapped that with some good electrical tape.
NitroNate 06-02-2010 12:46 PM
seconded. solder paste and a butane torch with some heat shrink tubing will make quick work of it.
beenthere 06-02-2010 12:51 PM
Wrong type of splice.
Can become a loose splice from expansion and contraction in just a few years. And burn up your motor.
liquidvw 06-02-2010 01:58 PM
I did the WU splice and followed it up with solder. Hopefully that will stay together.
Yoyizit 06-02-2010 02:24 PM
Anything written in 1926 can't be wrong :laughing:
liquidvw 06-02-2010 02:39 PM
And how has the western union spliced changed?
