Motor on fire
Then it probably completed a circuit to ground. You will get an induced voltage ( around 100 volts) in unusued wires in a multispeed direct drive motor. Should have arced and blown the breaker. Do you have a 15 amp breaker/fuse? If larger then that could be the problem too as the motor could burn B4 a larger breaker trips. Sounds to me like you got voltage on the neutral wire or ground wire and something else is wrong or that bare wire sent voltage to the ground and backwards to the motor. Do you have electric elements as well as the wood stove? Post some pice of all the wires and the relays.
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
