Most Efficient Method To Operate Home Heating System - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2013, 10:59 AM   #1
Rewards Points: 55
Most efficient method to operate home heating system
My heating system is baseboard hot water from a oil fired boiler. I have a question about the most efficient way to operate this system. In the winter, we set the daytime temperature at 66 degrees & lower to 58-60 at night. In the morning when we move the thermostat to 66, the system runs for quite some time in order to heat the house back to 66.
(1) Would it be more efficient for the night setting to be higher, say 62 degrees, so that the system does not have to run so much in the morning?
(2) Is there a way I can run an experiment to determine the most efficient night temperature setting?
Thank you.
goshenplumber is offline   Reply With Quote
Old 10-25-2013, 02:27 PM   #2
An old Tradesmen
Rewards Points: 8,154
A 6 to 8 temp rise is going to take a while.And it should be expected. Your operating it fairly efficiently now. A smaller set back will mean it doesn't run as long to recover, but that it uses more oil over night. Reducing the amount of oil you save.
Turn thermostat to COOL (mobile home split system), fuse on control board blows. justplumducky HVAC 8 04-29-2013 07:42 PM
Heating System Check Valves ajberezo Plumbing 2 04-11-2013 12:13 PM
Recommendations for heating and cooling options for my home? daluu HVAC 2 12-23-2012 01:31 PM
Hydronic Air PEX Piping Deteriorating - Repipe or Install New Heating System? aoreo HVAC 9 06-25-2010 07:36 PM
New To Hot Water Home Heating System Midicat HVAC 2 10-14-2007 08:12 PM
