More Cold/less Hot Air In Only One Room - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 12:01 PM   #1
more cold/less hot air in only one room
When the AC or the heater is blowing air, all rooms but one have the expected temperature, although not exactly the same, but acceptable. For this particular room (the master bedroom) , when the AC is on, it is much colder than other rooms, and when the heater is on, it is not very warm. When I adjust the damper, the temperature in this room is still lower than other rooms, it is either too cold ( when the AC on ) or not warm enough ( when the heater is on ).
Any advice is greately appreciated.
dt164 is offline   Reply With Quote
Old 11-01-2011, 02:32 PM   #2
An old Tradesmen
Rewards Points: 8,202
Choke down the dampers to the other rooms.
The Following User Says Thank You to beenthere For This Useful Post:
dt164 (11-02-2011)
Old 11-02-2011, 07:01 AM   #3
Thanks. It works !!! I thought choking down the other rooms' dampers would make this room colder because it gets more cold air, but surprisingly it really makes this room less cold with A/C, and warmer with heater.
Still don't understand why , but I really appreciate your help.
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 02:49 PM
Bathroom to Laundry Room to Bathroom bcatanz10 Remodeling 2 10-10-2011 09:45 PM
Vapor Barrier on elevated 4 season room Indyc0lt Insulation 3 09-15-2011 01:41 PM
advice/Help on non-permitted bonus room? Orange_County General DIY Discussions 43 06-11-2010 05:06 PM
What Makes A Room A Bedroom? HowToGuy Remodeling 11 02-26-2010 02:44 PM
