Old 10-30-2007, 12:27 AM   #1
Default More Advice Please
I have a 18-20 year old Carrier gas furnace and air conditioner. I am thinking about replacing the furnace in the next couple of weeks as a proactive measure. I am thinking about replacing the A/C as well at the same time and a humdifier. The furnace that I am thinking of buying is a variable speed 95 efficient. More options are an upgraded filter, ranging from $400-$1000, and UV lights.
Can someone here provide good guidance? Is it wise to be proactive, or wait until it breaks and hope that it isn't -10 degrees. Also, what about the air filters? My family doesn't have any real allergy problems.....
Please shed some ideas and advice...
Kyle is offline   Reply With Quote
Old 11-13-2007, 12:27 AM   #2
I'd recommend shopping for a Goodman or an Amana, both are now made by Amana which gets very good ratings from most installers I know.
You should begin hunting for a unit that has fewer BTU's than what your system has as of now. the current logic and energy efficiency comes from using smaller units that need to cycle for multiple shorter periods rather than the oversized that cycle fewer times with more gas output per time.
The increased energy efficiency for a furnace with a rating over 80% comes primarily from the units having the capacity to reburn the emmissions before they leave out the vent.
RemodelMan is offline   Reply With Quote
Old 11-13-2007, 12:53 AM   #3
no loose ends
Default Replace it!
When I see a furnace or ac in need of repair, and its this old, I would try to encourage you to replace it. Though it works now, you're prolonging the inevitable--not to mention the fuel and energy your waisting, and the cost of equipment isn't getting any less expensive anytime soon.
Goodman bought Amana. Unless their policy has changed, getting parts is like pulling teeth--this may not be so everywhere, however. Check 'April-Aire'--I think thats there website. They'll have everything your interested in for home air filtration/purification/humidification.
undone is offline   Reply With Quote
Old 11-16-2007, 10:42 AM   #4
What part of the country are you in? Dual fuel is a much cheaper way to heat and if you are replacing your cooling anyway, the cost is not tremendously more.
I agree with replacing it based on the age. Have a load calculation performed, I personally feel, if it isn't offered, than I would not use that contractor.
U/v lights we are finding out in most cases don't work effectively enough(unless you buy many) and can damage ductboard and drainpans.
Newer filters are effective, but the question is ALWAYS what kind of shape is your duct system in.Most duct systems are undersized and leak 20% or more of their air.Adding a high quality filter to an undersized system can put more of a strain on it.
VAheatcool is offline   Reply With Quote
More On This Topic
Hello, My name is Mac and on behalf of expertvillage.com I would like to talk to you about welding shop ventilation. Now inside of a welding shop, we have already talked about the different types of gases that we use and the smokes that can occur when... Read More »
The Polaris all-terrain vehicle, or ATV, is a popular brand of four-wheeler. This recreational vehicle allows riders to go off-road to enjoy rougher terrain. The maintenance for these vehicles is very important, though, as riders can find themselves in... Read More »
Creating delicious meals for the family at home also creates tantalizing aromas in the air. However, you need proper air ventilation to remove odors from grease, smoke and moisture. Whether you're redoing your kitchen or building a new home, several... Read More »
Basic maintenance is vital to the long-term use of any motor vehicle. With the price of fuel and the cost of experienced technicians on the rise, the need for many cyclists to perform scheduled maintenance themselves and conserve their riding budgets has... Read More »
How to Use a Duct Blaster
How to Use a Duct Blaster by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test on this house. This is a duct blaster right here. Okay the reason we are hooking up to the return side of air and maybe I need... Read More »
Need Sheetrock repair advice Giterdone Carpentry 6 02-03-2007 10:38 AM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-02-2007 12:16 AM
Painting over panelling - seek advice deb14905 Painting 13 10-13-2006 09:26 PM
Landscaping with D6 - Need advice cjcocn Landscaping & Lawn Care 0 07-07-2006 12:44 AM
bathroom wall advice bigbrad123 General Discussion 9 06-07-2006 09:26 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
