Monoflow Sytem Q's And Adding A Radiator - HVAC - DIY Chatroom Home Improvement Forum
Old 08-23-2009, 12:08 PM   #1
Monoflow sytem Q's and adding a radiator
Hello all,
I am looking to add a radiator in one room of my basement. The room is 12x20 three outside facing walls, non insulated. Basement is 75% below grade. Winter temp in this room can get as low as 55 degrees. I see myself having two options, add a zone, or tap into existing system. After doing much reading about my system I am starting to get more confused, not better educated!
Hydrotherm HC-85B 68,000 BTU boiler, cast iron radiators all on the first floor. The first potential problem I find is that there are many unused, capped off monoflow tees! From what I read this is not a good thing. The system has 7 cast iron radiators, each one uses one monoflow T and one regular T. What I found was that at each radiator T on the main line there is an extra monoflow and regular T. Why? no idea, this is how I bought the house.
Since I have all of the extra T's can I use them to run extra radiator(s)? Can I mix a baseboard radiator with the cast iron? all of the main radiators feed off the pipe located at the basement ceiling, the new radiator would need to have the pipe come down off the ceiling pipe and back up.
This is the direction of system flow: boiler, living room, hallway, kitchen, bedroom 1, bedroom 2, bathroom, dining room, circulator pump, boiler. This new radiator would be between bedroom 1 and 2.
Thanks in advance for taking the time to read all of that!
jaytech33 is offline   Reply With Quote
Old 08-23-2009, 06:10 PM   #2
An old Tradesmen
Rewards Points: 7,744
Need 2 mono flo tee's for each basement rads. Or the hot water won't flow down.
adding a radiator wombosi HVAC 5 02-16-2009 05:32 AM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 08:45 PM
Adding Kitchen pass through to an existing opening? sscott0203 Remodeling 7 12-13-2008 03:17 AM
Adding insulation to only a portion of an attic? curls00 Building & Construction 22 10-27-2008 09:41 AM
Adding new duct/Register CEbury HVAC 1 06-25-2008 10:51 AM
