Old 10-02-2011, 07:43 AM   #1
Monitor Oil Heater
I took on a charity job to install a used Monitor 4100 Oil Heater for a distant relative. It is about 12 years old??? (They think) and had been in storage for several years. You guessed it. It won't light. It goes thru the motions. Anyone know where I can find repair manuals, info or parts??? They love this thing.
Roundman is offline   Reply With Quote
Old 10-02-2011, 10:03 AM   #2
Monitor Oil Heater
No good deed goes unpunished.
Did you do the annual cleaning procedures?
Master of Cold is offline   Reply With Quote
Old 10-02-2011, 04:05 PM   #3
Monitor Oil Heater
No I did not do an annual cleaning. first one I have ever seen. Bet it has never been cleaned. Can you explain the procedure.
Old 10-02-2011, 04:32 PM   #4
Monitor Oil Heater
I don't actually know the cleaning procedures. I am the master of cold, not heat
One of these old yankees will be along shorty to tell you how to do it..
Old 10-02-2011, 06:04 PM   #5
Master General ReEngineer
Bondo's Avatar
Monitor Oil Heater
Ayuh,... Have a look here,....
The Following User Says Thank You to Bondo For This Useful Post:
Roundman (10-02-2011)
Old 10-02-2011, 07:01 PM   #6
Monitor Oil Heater
Thanks Bondo, That is a great help.
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Min distance from baseboard hotwater heater capslock General Discussion 2 05-25-2010 08:31 AM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
