Monitor 441 Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 09-08-2013, 05:59 PM   #1
Monitor 441 heater
Looking for some ideas on how to fix my monitor. The heater heats up to temperature just fine. When it goes in to shut down after reaching temperature it stops working and goes into flash mode.
Alf572 is offline   Reply With Quote
Old 09-08-2013, 07:26 PM   #2
Rewards Points: 13,300
No code showing in the little window?
http://monitorproducts.com/wp-conten...es-M22_M41.pdf
Old 09-08-2013, 07:32 PM   #3
Page 24.
http://monitorproducts.com/wp-conten...nersManual.pdf
Any chance it was allow to run out of fuel just before this started happening so now there's air in the line.
Old 09-08-2013, 07:46 PM   #4
Monitor 441
The heater heats up to temperature just fine. I am assuming that would indicate that I do not have a fuel issue. I do not get error codes. I just see the flashing bars.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 09:48 PM
Central heater works only when I help jump start the motor by turning it. stanlam HVAC 10 12-11-2012 06:24 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 12:35 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
