Old 11-10-2008, 07:50 AM   #1
monitor 441
Hello everyone i have a monitor 441 actually 2 i just had a heat exchanger put in by local fuel company in one. My other heater the air intake/ combustion motor went and i can't find parts anywhere online. Havin trouble finding tear down diagrams or manual aswell can you get anything online for these things? i really would like to find proper name of this part i need aswell as pricing if any one knows of anything thanks
jaycar13 is offline   Reply With Quote
Old 11-12-2008, 02:50 PM   #2
monitor 441
re air intake/ combustion motor most common problem with this
is the bearings. I use MRC 38ff bearings, you will need two and
its quite a job to take out.
The bearings are around $6.00 each but takes me around one hour
and I have replaced them in every heater I pick up.
Be sure you use a good bearing as most of the cost is in the labor, I keep
bearing on hand so I do not have to run out to my nearest Bearing Shop.
msearcher is offline   Reply With Quote
