Monitor 40 Heater - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-13-2014, 08:23 PM   #16
chitownken's Avatar
Rewards Points: 510
Glad to hear that your heater is running again.
chitownken is offline   Reply With Quote
Old 03-15-2014, 08:31 AM   #17
I am so confused with this heater . I have purchased 3 different filter replacements for my general filter. Each time i put the filter in my monitor heater stops working. when i omit the filter the heater runs great like it supposed to. I have @ 5 inches of fuel in my tank so no problem getting fuel.
popi1 is offline   Reply With Quote
Old 03-15-2014, 08:45 AM   #18
An old Tradesmen
Rewards Points: 8,234
How high is the bottom of the tank above the monitor heater?
Old 03-15-2014, 09:12 PM   #19
@ 3 ft above heater. Heater has been in use for past 5 yrs at same position
Old 03-16-2014, 04:14 AM   #20
An old Tradesmen
What brand and model filter are you using.
May have a restriction building up near the opening in the tank.
Old 03-16-2014, 07:30 AM   #21
Thanks beenthere it is a general filter 1a25a. Is there another type that I could get. I need the heat but don't want to mess up my heater either.
Old 03-16-2014, 08:38 AM   #22
An old Tradesmen
I would use the gray wool filter element instead of the white gear cog looking one. Although they have the same rating. I find the gray one seems to allow oil to flow through it easier.
Old 03-16-2014, 11:36 AM   #23
I have tried two gray ones and one white they all do the same thing. It is so crazy not sure what to do next.
Old 03-16-2014, 12:17 PM   #24
An old Tradesmen
Blow out oil line to see if there is anything restricting it.
Old 03-16-2014, 12:48 PM   #25
Thanks will try that when weather breaks
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Need input on indirect fired water heater install. A Squared HVAC 13 11-23-2013 04:42 PM
Water Heater Height Factor in Install Cost? hefret Plumbing 9 10-10-2013 10:01 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
