Monitor 40 Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 03-06-2014, 11:35 AM   #1
monitor 40 heater
I have a monitor 40 heater when i start up the heater the flame is blue
for @6 min. then changes to orange flame status light begins to flash and
fire goes out. desperate in need of help
popi1 is offline   Reply With Quote
Old 03-07-2014, 05:54 AM   #2
An old Tradesmen
Rewards Points: 6,540
Post pic.
Old 03-08-2014, 03:13 PM   #3
monitor 40 heater
where can I find a complete troubleshooting manuel on a monitor 40 heater.
Old 03-08-2014, 03:33 PM   #4
Rewards Points: 13,296
Google it.
Old 03-09-2014, 08:40 AM   #5
popi1
Thanks Joe I did go to goggle they had everything but not for a monitor 40 heater or any monitor heater.
Old 03-09-2014, 10:48 AM   #6
chitownken's Avatar
Rewards Points: 510
Try this:
http://nortonsafe.search.ask.com/web...=en_US&tpr=111
5th one down is manual
chitownken is offline   Reply With Quote
Old 03-09-2014, 06:53 PM   #7
Thanks Chitownken got the manual however it does not show my problem in the troubleshooting section
Old 03-09-2014, 07:31 PM   #8
chitownken's Avatar
Rewards Points: 510
Did you clean the strainer and verify that there isn't crud in the fuel?
Old 03-09-2014, 07:47 PM   #9
not yet will that keep the fuel from going to burner
Old 03-09-2014, 07:58 PM   #10
chitownken's Avatar
Rewards Points: 510
Yes. If the strainer or the filter (if you have one at your tank) gets plugged it will cause the heater to starve for fuel, just as if the tank was empty.
Old 03-11-2014, 09:10 AM   #11
cHECK THE FILTER AND IS CLEANED ALSO CLEANED THE AIR INTAKE AND EXHAUST LINES BLED THE TANK FILTER STILL DOES NOT FIRE. COULD IT STILL HAVE AIR LOCK
Old 03-11-2014, 09:20 PM   #12
chitownken's Avatar
Rewards Points: 510
It's all gravity feed, isn't it? When you disconnect the fuel line at the strainer you should get fuel flow. Did you pump the fuel set lever a couple times? There has to be a flame sensor somewhere in the unit so that it can verify that the ignitor actually lit the fuel. See that there are people selling fuel pump and carburetor assemblies on ebay so that is another part that could have issues. I would try to find the flame sensor first. If it is the type that has a mica window that faces thee flame, make sure that window isn't sooted up.
Old 03-12-2014, 06:48 PM   #13
I noticed when i pulled the strainer out the small tip was in first then i saw a pict of one on side of heater the tip was toward the metal plate is that the correct way
Old 03-12-2014, 10:12 PM   #14
chitownken's Avatar
Rewards Points: 510
Don't know the answer to that one.
Old 03-13-2014, 11:00 AM   #15
Good morning Chitownken its march 13 and got great news my heater has been working for @ an hour now. After going through everything I decided to do one more thing and that was to remove the new filter outside just to see if i would get fuel. it fired up imediately. The filter must have been wrong or something. Off to buy another filter. Thanks again for all your advice and help. Have a blessed day
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Need input on indirect fired water heater install. A Squared HVAC 13 11-23-2013 05:42 PM
Water Heater Height Factor in Install Cost? hefret Plumbing 9 10-10-2013 11:01 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 09:48 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 12:35 PM
