Mone Of My Apartments In My Building Is Not Receiving Adequate Heat (the Largest Apartment In The Building) - HVAC - DIY Chatroom Home Improvement Forum
Old 12-14-2010, 09:43 PM   #1
mone of my apartments in my building is not receiving adequate heat (the largest apartment in the building)
i need new floor (border style) radiators or heating apparatus for my apartments because i purchased a new boiler and some of my apartments are not receiving adequate heat. can this be one of the problems?
sweetiepie2 is offline   Reply With Quote
Old 12-15-2010, 02:42 AM   #2
if you have the same radiators in the working apartment i would say no.
but be patient and a boiler guy will answer you more accurately than i can..
hvaclover is offline   Reply With Quote
Old 12-15-2010, 04:37 AM   #3
An old Tradesmen
Rewards Points: 7,328
If they heated before with the old boiler, then they aren't the problem.
Are the apartments that aren't heating, the higher level apartments. if so. May be that the water pressure isn't high enough to have water flow through those baseboards.
How high are they above the boiler. What is the water pressure in the boiler.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
HELP old apartment .. Return Duct / Heat pump thethrowdown HVAC 1 01-29-2010 03:36 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
